SOURCE: SAP - I can't get my new TV out of Mono and into stereo.
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
SOURCE: Akai LCT2070 Stereo Sound
This tv is kind of got a mind of its own the only time you can adjust it on mine is on cable that comes in stereo actually it usually switches by itsself after it reads the broadcasted sound. Hope this helps.
SOURCE: sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
SOURCE: mono stereo sap on screen
you need to reset the preferences on you sound icon in the menu panel
from your remote
Press MTS to select a sound mode if available with the TV programming: MONO,
STEREO, and SAP.
