Checked the wiring didn't find any cracks..... starter looks good no loose wires..... checked all grounds and they seem to be all tight.
SOURCE: When I try to start my generator the code oc comes
Check battery volatge while you are cranking engine if voltage drops below 9 vdc you have a bad battery. If it doesn't you probable have a bad starting solenoid or a bad ground at the starting solenoid.
SOURCE: is not charging put on new battery run it down in
check the alternator output straight from the coils usually around 18 volts ac if this is good may be down to the charge regulator / rectifier
