Try a reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: I have a Philips 42PFL7662D/05. No picture
We have the same telly and had the same problem. Ours was bought Jan 08. It can be repaired, as we had ours returned from the philips repair specialist yday, but it cost £190.
SOURCE: PHILIPS 42PFL7662D/05 FAULT.
Just posted about this - ours was exactly the same. Had it returned from the Philips repair specialist yday - cost £190. not a cheap fix.
SOURCE: Philips 42PFL7662D problem
I come across this every day with LCD Tvs.What it is, is dust between the layers of the LCD. When dust particles settle behind the front layer of the LCD, and the LCD is pressed i.e when cleaned, the layers can be pushed together, resulting in a shadowy streak. If the LCD is stripped and cleaned it will be ok.
SOURCE: PHILIPS LCD 42PFL7662D/12 HOTEL MODE
You have to enter its service menu option to unlock the Hotel mode. Visit the site named 'Electro-help' for more details. Check this LINK and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs.
