There's a really useful kiddicare video about how to use your quinny buzz on Youtube:
http://www.youtube.com/watch?v=6DYLOIa-Ik0
I think the demonstration of how to fold down the pushchair is at about 4:30
Download the manual at http://www.quinny.com/quinny/faq.aspx?language=gb-en
SOURCE: Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
SOURCE: how to fold a quinny
Hi, you can download the manual from the quinny website, but as a quick guide, the best I found was - first stand with your foot against the front wheel (so it doesnt move forward) then press the grey buttons on either side of the chassis and at the same time draw the frame downwards towards your foot, please remember you can only fold down with the seat in place if the seat is facing forward (ie baby facing outwards) it wont fold down with the seat facing mum, there are also demos on you tube, hope ive helped and not been too complicated :)
SOURCE: Problem in folding quinny buzz to stiff
I would suggest that when folding the Buzz, stand in front of it first. Push down one of the grey buttons, then slide and push the other, then you can use your whole body weight to push the pram to the floor enabling you to collapse it. It is also easier if you remove the seat prior to folding.
I hope this helps.
SOURCE: Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
SOURCE: how do you fold a quinny buzz?the instructions
position the pram so the front wheel is facing you,put your feet either side of the wheel to stop the wheels moving
push the two grey button that are on either side and as you push the buttons pull down the frame towards you.
hope this helps.
