Cars & Trucks Logo
david Posted on Apr 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a strider md4 plus i came out to it one morning and wouldnt move its showing the fault code 2 flashes could anyone tell me what it may be many thanks
Jeremy W.
Level 3:
Top Expert:
  • Cars & Trucks Master 5,332 Answers
  • Posted on Apr 17, 2016
Jeremy W.
Level 3:
Top Expert:
Answers
5332
Questions
0
Helped
2057907
Points
17799
2 Related Answers
Anonymous
  • 747 Answers
  • Posted on Jun 28, 2012
SOURCE: Fault code is P0183
this is the fuel temperature sensor a circuit high input reading
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 13, 2013
SOURCE: grand vitara fault code PO135
O2 sensor heater fault.
1helpful
How can you tell if a new gearbox is needed other than a Ecu which has been replaced
have the fault codes read first
if the car is moving in limp mode with no obvious noises or problems , replacement of the box is a total last resort
light on the dash and limp mode can be transmission or engine or both but the fault codes will show the problem area
The ECU -- engine control unit or ECM --engine control module gets messages from the transmission control module ---TCM--and that TCM controls solenoids and servos , vss and other items that if faulty will put the car in limp mode
read the fault codes
2helpful
2answers
Engine management light flashing. Mechanic s computer - no fault code detected. Now light off for few days and has come back on. Any ideas
Based on that, anyone who tells you they know what the problem is would just be 100% guessing.
2. The mechanics scan tool may not have picked up a code but that does not mean there is no fault code generated ready to be pulled up with the correct equipment. There are also some manufacturer specific codes for various models that many generic scan tools will not necessarily read.
3. I would take it to a dealer service center and have the fault code or codes pulled up and diagnosed as there will be something if the warning light is back on. Whatever fault codes are being generated, their equipment will pick it up.
2answers
How to reset abs light
The ABS sensors may be at fault; misaligned or damaged.
My expedition wont drive foward but will drive in reverse what could the problem be
Sounds like you lost a solenoid or two in the transmission. Worse case would be burnt clutches or bands. It needs to be on a scanner to tell for sure. A code reader will only pick up a generic 700 code. Not the codes you need to know. Plus with a scanner you can command solenoids on and off and tell if they are working.
2helpful
2answers
Malfunction indicator light came on, it was fine last night but when i started it this morning the light came on and stayed on while i drove to work, it did not flash, just stayed on constant.
Go to your nearest Auto Zone store and have them put their computer on your vehicle, to see what code comes up (IT FREE). They should let you know what the problem it...if not....let me know what the code is and I will let you know what is wrong..Hope this helps you ??
2helpful
2answers
Fault code
There you have two codes:
1 2 or 12 = Battery recently unpluged
5 5 or 55 = End of Test.
So, you dont have malfunction codes in there, this is good.
More details can find in :
- Read Check Engine Codes
- Reset ECU Procedure
Hope help with this (remember rated this DIY and this post, an comment it).
7helpful
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Issue with my Megane 03 plate --electronic fault-
dealer only factory immobilisor has cut in when battery went flat
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
