Need model number of your range to answer this question. Is this gas or electric? Is this a freestanding range or cooktop because I only can find information on ranges with this fault code given. All should EEPROM communication error which is a communication error on start up. when the top was damaged was the unit being used? Was water or liquid a factor when this damage happened? A loose wire would be a different error code or fault code like a F2 - E1 or E2, not your code given. I hope this helps, need more information. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board. I would need the entire model # on sticker on the oven to see what parts are on this one. If the touch pad is separate it will have a ribbon that goes from it to the board. Unplug that ribbon, if the code goes away then the touchpad is the problem. If the code stays with the ribbon unplugged then the control board is bad. Make sure power is off to unit when touching anything!
