Washing Machines Logo
s
siphesihle Posted on Apr 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
The door sensor is not working the beeper goes on as door open
Anthea Scott
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 29, 2018
Anthea Scott
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
454
Points
I have a fuzzy logic 8.2 kg. When it comes to spinning the machine makes a massive noise..
Tedowen
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • LG Expert 536 Answers
  • Posted on Apr 25, 2016
Tedowen
LG Expert
Level 2:
Prodigy:
Answers
536
Questions
0
Helped
264641
Points
943
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
How to soak somethings overnight in my new LG washer ?
The method we use on our LG WF 8071TTP top-loader:
Load stuff to be soaked.
Add soap.
Set load size and water inlets.
Start wash cycle.
Wait until water is full, and begins washing.
Press Start/Pause button.
Press Auto Stop button to switch machine off.
Next morning:
Press Auto Stop button to switch machine on.
The fuzzy logic (if machine has this) will register that machine is full, and washing will continue.
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
1helpful
2answers
Have a LG fuzzy logic 8.2kg wf -8071ttp it gives a de error
DE usually means door open,can also mean that door lock not working
DE error massage on lg fuzzy logic 8.2 kg 8071TTP
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Hi I have a LG Fuzzy Logic 8.2kg WF-8071TTP washing machine. It washes but does not spin dry. Please heelp
may sound crazy, but sometimes the water pump gets clogged and does not operate, so will not spin. safety feature, I guess.
Try cleaning out pump.
Bruno
2answers
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Fuzzy Logic 7.5 kg WF-T753A not agitating.
short answer, its not easy. i believe its run by a gear assembly. i would hire a pro to at least diagnois it.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
