Hello friend, thank you for your post!
Based off the information you have provided your Electrolux dishwasher does not have power. When was the dishwasher installed? It is possible that your installer might have missed a connection to supply the power. You may also want to check the breaker box to assure that it has not shorted and flipped a breaker. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
From what you have described your Electrolux dishwasher finished the cycle then beeps and will no longer work. I would suggest performing a reset on your range and you can do that by disconnecting the power for roughly ten minutes. If you power your dishwasher back on and continue to have issues with your dishwasher not working I would suggest that it could be an issue with your control panel. You may need to seek assistance from a professional technician for proper diagnosis. Hopefully this is helpful. -Matt
Hi dan76n - Typically PF appears in the display when the dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad. If it proves to be ineffective, once again try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and select a cycle. If the problem continues, the dishwasher could possibly be experiencing a wiring failure or faulty board. At this point I will highly recommend connecting with a certified technician for a further diagnosis and to accurately assist with the repair(s).
