HP Color LaserJet CM6040f MFP Q3939A Printer Logo
O
Ole Elniff Posted on Apr 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Initalising scanner wait a moment
The display say,s : Initalising scanner - wait a moment the scanner d,ont move at all can you help no error codes
Alzubaidi Firas
Level 2:
Habit-Forming:
New Friend:
  • Expert 64 Answers
  • Posted on Apr 17, 2016
Alzubaidi Firas
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
64
Questions
7
Helped
21203
Points
101
I would strongly recommend to delete your printer driver and re installed a new one online.
Laser scanner unit error. Turn off the printer,then contact the store you purchased the printer inform them of the error code displayed and symptoms. Error Code: E100 0000
that is what you should be doing as it is a warranty repair problem, not contacting fixya because you have a direction of what to do
1helpful
2answers
http://fix-your-printer.blogspot.in/2009/03/canon-lbp2900-error-code-e100-0000.html
Error code E#100, ERR 100 or E100-0000 is a laser scanner unit error.
Solution 1:
Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
Flip open the top of the printer.
Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
After you move the laser, unplug the printer for a few minutes.
Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative.
for other more help visit https://cbrtechsolutions.net
Avast wont automatically update
Uninstall and Install avast on your system again. I hope it will work.
1helpful
I have canon ir3750. When I switch on the machine it goes to the start screen , The screen displays wait message, for about 3 minutes and than nothing happens and then the error code message comes up...
This is an error in the communication with the scanner. Check or reseat the connectors from the scanner , check to see if the scanner even moves during initialization ( power supply for it may be bad ), check/replace reader controller, scanner board, or main controller of copier. I've not seen this error before. Good luck.
1helpful
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
12helpful
Scanner motor move failed error code 6202
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
E36 318i k reg
when the window has reached the top position keep the window switch up for 15 sec,operate the window complete down and when down hold the window switch down for 15 sec test this after. all you are doing is to teach the control unit the limit stop and open position.
Casio TE 2200 Needs mac codes
Hi.
What MAC code did you use? Are you getting an error on the display? Please describe what you have done so far and I'll try to help.
Mark
2answers
OS problems
i have a copy of the pc INSallation cd fo windows 98/me2000/xp. also a zip fle of the folders on the player these you need to replace to get the player pass that the initalising screen.
2answers
Problem on t.sonic mp3 player
Check the battery i think it`s dead
k24674
Grand Canyon Tech
Grand Canyon Tech
