SOURCE: Brother DCP-130C Printer.. not Printing.... When i give command from computer
try to reinstall the usb drivers. Delete before by help of the agressive remover which is part of the install cd (you have to open the cd).
Connect printer directly to usb of pc . DO NOT use a hub.
hope it helps
SOURCE: "Shuttle jam" see manual problem on Printronix line matrix P 500E printer
Verify that there is nothing clamped between the platen and the shuttle.
Last time I had this fault, it turned out to be a broken wire in the harness that connects the CMX board to the shuttle module.
Other possibilities include a failed shuttle or CMX board.
Steve W
LazerTek LLC
SOURCE: Printer is not printing
The error is a loss of laser beam detect error. Your problem is the laser scanner has burned out. The replacement is easy to accomplish. You simply have to remove the full top cover (3 screws and 1 clip near front right corner). You'll need to remove the side cover first. Once the covers are removed, look for a large black box (about 4" x 6") held in place by 4 screws. The part is available from Dale at Seattle Platen, 1-800-221-2388. Ask for a refurbished on exchange.
Hope that helps you.
SOURCE: printer dont print 2 command
i experience it before but i just restart the pc and printer or the printer itself and after a while its ok..^_^..
SOURCE: printer is installed and connected properly but
try pressing on file print and change the icon from printer...... to the printer you inistalled as example turn it from hp 800c to mfc-7340
