SOURCE: Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
SOURCE: Hook on Jabra BT125 ear
You can buy a 5 pack here:
http://www.shop.jabra.com/jabra/Shop?Dsp=30007&PCR=1:401&actn=addkeycodetocart&keycode=5JABRAST400
SOURCE: Have new Samsung Alias 2 that won't pair to my
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
SOURCE: Jabra BT135 won't pair with my Iphone -
take the Bluetooth device and keep its button pressed till the light stables that is u will have to hold the button for more then 10 seconds!!! then once the light is stable keep it like that and take the phone and search for Bluetooth devices it will find it now and then enter the pin given in the manual or mostly it is 0000 and pair the two devices now u are ready to use it!
enjoy!
reply and rate!!
Testimonial: "Wow - what a fast answer! Really much appreciated, thank you. I did just as you said and got my bluetooth headset connected straightaway. Once again - thanks for the superfast response"
