Dodge 2005 Grand Caravan SXT Logo
A
Autumn Ford Posted on Apr 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where are the muffler bearings on a 2005 dodge caravan
  • Brad Brown Apr 15, 2016
    Hi Autumn Ford, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Are you sure of your terminology because there is no such thing
Steve
Level 3:
  • Master 696 Answers
  • Posted on Apr 15, 2016
Steve
Master
Level 3:
Answers
696
Questions
Helped
239438
Points
55809
They can be found next to the blinker fluid at your local automotive store.
Muffler for 2000 dodge caravan
You show 2 vehicles, a 1999 Ford Escort, and a 2000 Dodge caravan. What do you want to do with the muffler? Find one or fix it?
No power on highway going up hill.
Sure could. A good choice is going to a trustworthy Muffler shop. They have a test that can tell you how good they are. Their Converters are less than Dodges.
1helpful
In my 2005 dodge grand caravan something under the hood is making a grinding noise it is constant while running and sometimes goes from loud to quite to loud Wut is it?
It's one of the pulleys that needs to have the bearing replaced most likely. Check for wobbling pulleys where ever the belt makes contact.
2answers
How do i replace the catalytic converter on my 2005 dodge grand caravan 6 cylinder
I would take it to the muffler shop, newer vehicles have to many sensors. It could make for more problems if you don't know much about them. I would take it in to a shop and they will put one on fairly cheap.
8helpful
2answers
How Do i remove Rear wheel bearing 2005 dodge caravan
raise van take off wheel you must use jackstands or support your van securly its going to rock alot Take off the four bolts located on the back side of the bearing then take out the small bolt from the speed sensor also located in behind the bearing remove the speed sensor. you will need a large mechanics hammer or heavy blunt object. beat the bearing from the back side dont worry about the cog attached you new bearing has one. dont listen to your hanyes or chiltons manuals thanks.
Muffler blowing white smoke
take it back the engine has a blown head gasket or cracked head all cost over 1200 to fix
2005 dodge caravan
Seeing how obviously I can't hear what your hearing, I'll say this much, there's a good chance your hearing the upper strut bearing or bearings starting to get worn, pretty common problem with caravans, but just to be on the safe side, have front end checked out for your own & everyone else's safety, just in case. Should only take 10 min. or so, for piece of mind.
Top Dodge Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
