Ix1000.1 hooked up backwards fml right when I was buying it today so just bought a brick can I fix it
If you have connected the power supply up backwards (crossed over plus to minus ) then im afraid you've damaged it internally , but if you have only connected the speakers backwards , that's not too bad . unpower it and ck your wiring to the speakers make sure all the speakers red or + goes to the positive or + on the amp and the negative goes to the other terminal
I'm trying to learn how to fix it. Internaly. Not hook it up.
OOhh!!! well then the technical description of what maybe wrong is the semiconductors have been reversed in there polarity and have drawn infinite current thru there P/N junctions and quickly overheated to the point of becoming now a full conductor , now no longer a semiconductor anymore
Ok so can there polarity be reversed again or do I need new semiconductors. Also which thing is the semiconductors do I just solder new ones on there and where can I get the new conduct
Sparks and smoke flew. Then I tried hooking it up the right way and it continued to spark so that's where I'm at now
ive had some dealings with kicker equipment before (I prefer not too) they don't put anything (savior devices) inside there items to prevent a show of sparks when they aren't connected up to power the right way , Hope it wasn't too expensive !!!
