Hold the power button and the volume up button when u see the screen come on let go of the power button but keep holding the volume up button the android man will pop up u after hold the power button amd tap the volume up button the recovery screen will pop up go down with volume down button to wipe data press the power button to select it go down to yes then select that it will erase the table it will go back to recovery mode the go to reboot select that and it will restart your tablet
This process requires lots of patience and dogged determination and a few softwares which you'd need to download online.
Basically, what you'd be doing is to FLASH your Tab's firmware.
1. You need the original ROM file (run a check on needrom.com) or check online.
2. You need SP flash tool
3. You need a laptop/PC you can use
4. You need USB drivers so the PC can recognize or successfully connect with your tabs.
5. You require a USB data cable to link the PC and your tab
Any other tip/guide you require will be contained in the SP flashtool zip file you download.
And we're supposed to know what wrong with it?
How about if you provide some additional information.
Like what is it doing or not doing.
Great place to start.
