I assume you hooked up a mechanical test gage to see if the oil pressure is really low or the oil pressure sending unit that measures it is defective?? If you did this and you know for sure that it really is low pressure then the problem would be a worn engine bearing letting the oil pressure bleed off.
Is it made by the Broaster Company or a spin off like a Henny Penny? Is it gas or electric? If by the Broaster Company would it be a 1800 or a 1600? Give me this information and than I can tell you what the problem is. Not an expensive fix either.
Check the wires at all connections for burnt insulation. This could be where your smell is coming from. Also make sure something is not burning the well if it is plastic.
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
i have iriver e10 in side some picturs i show in my player but i conect with computer there is iwe not show that picture i need that all picture what can i do ? without formet
E10 code indicates there is no water supply.This can be confirmed by :
Shut off the faucet to stop water supply to the washer.
Disconnect and pulling the supply hose off the washer to confirm the E10Code
Opening the faucet and watch for running water if you have water
Can be caused by bad pressure switch
Can also be caused by clogged pump
also by too low of a drain hose height. Check for clean filters of the inlet water line. Check that the drain hose was assembled as per the manual's instructions.
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply. a condenser dryer needs cold water to operate properly. the e10 code will appear if: 1. the water is turned off 2.the water pressure is too low. 3.the solenoid valve is open circuit 4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
