The relay seems like it stays energized, also the relay energizes as soon as I turn the main switch on
SOURCE: Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This
means unplugging the unit and plugging it back in. When powered back
on, select a brew function to see if the error reappears. This may take a few seconds.
If it does, ERR 2 indicates an internal error with the computer of the
warming plate. This may be covered under Kitchenaid's 1 Year Hassle
Free Warranty. I would advise you to call Kitchenaid Customer Service
to see what options are available to you. Repair is not recommended, as
it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
SOURCE: Coffee maker doesn't turn on when you flip the switch.
Hello evc622,
This is a really common problem with the cuisinarts. I am most familiar
with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of
the unit and in one of the corners you should find a filter stick or
column that is removable. Pull it out and open it up to clean out the
clogged up carbon filter in there. (You can later buy a new filter on
Amazon.) Clean out the debris from the bottom of the cavity. Replace
the stick into the cavity once cleaned. Now it's time to run through a
solution of 2 parts water and 1 part vinegar. Do this once or twice
with fresh solutions, then with a pot of fresh water. When the filter
stick is plugged up the sensor says its time to clean it or shuts the unit down, but most
people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
SOURCE: the coffee maker prematurely turns off at
Hello 1pro8vo2,
This is a common problem with Cuisinarts and is fixable.
I am most familiar
the unit and in one of the corners you should find a water filter stick or
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
SOURCE: cuisinart CBC-00 series coffee maker seems to have lost power
Yes it has a short. Mine did the same. Cost to much to fix, cheaper To buy new one, if under 3 years old cuisinart will replace for $10 shipping charge. 1-800-726-0190
