SOURCE: how do i wire my audio bahn speakers
This is a 6 ohm speaker, which should be wired to a 6 ohm outlet, but 4 ohm outlet is working, so allow it to stay like that. If you try to connect to 2 or 1 ohm outlet, the performance will actually worsen. In electrical theory, maximum power is transferred to a load (speaker) when the impedance is a match. You already have a mis-match of 6 to 4 ohm, but it is close enough. Try not to go farther away from maximum power transfer. Your speaker will draw too much current on a 1 or 2 ohm outlet and you may end up blowing fuses, too.
SOURCE: L7 wiring options
yes it should work fine i would bridge them up to 4 ohms each speaker then bridge them back bye conectin them on the amp by puting the red with the red and puting the black with the black if the amp only has 1 chanel then put both speakers red on the same positive on the amp and same with the negative now to bring the ohms up to 4 ohms conect the solid red to the black with dot with a short wire ok then the ones that are not run together will go to the amp giving offf 4 ohms and with the 2 speakers bridged together thay will reduce to 2 ohms witch means that eatch speaker will get about 600 wats of rms from the amp
SOURCE: How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
SOURCE: speaker wiring
hi mat
you should have four terminals two plain and two with dots
to get the best power cut two inches off good speker wire
tear apart now place one wire from
plan black to red with white dot then
plain red to black with white dot
this is how set then up with my directed 1100d mono amp .. very loud at half gain
well hope this helps.............. ..benjaminsarmy..
SOURCE: does two 1ohm woofer = 2 ohm
if you buy the 4 ohm subs you can drop each of them to 2 ohm and then down to 1 ohm between the two of them. going with the 2 ohm no matter how you wire them you will either get 2 ohms 4 ohms or 8 ohms. hope this helps by the way the 4 ohm solobaric and the 2 ohm are both the same price.
