If the jack is getting hot, don't plug it in any more. Sounds like you might have a short in the jack or on the motherboard itself.
When you plug it in, does it feel loose? if it does, you might need to have the connector on the laptop changed out. This is usually caused by daily use or an accidental hit to the plug.
What's the make and model of the laptop too.
Let me know:)
Gary
SOURCE: Dear Sir, My Dell Inspiron 6400 have problem
Hi your AC adaptor might be the problem. I repaired about 7 adaptor charger and I can you that this is the problem. Lot of time this unit is always be drop and the enternal parts such as transformer wiring solder to a little board are all broken off and no connection to the transformer or to the board. Just buy or order it to dell web site and cost is depending to the model of your laptop. I believe the cost is under $100.00.
