Dishwasher door seams to be in the lock position with the door open. unable to close or reset system.
Good Morning Garthraie, thanks for your post!
I see that the door on your Frigidaire dishwasher appears to be locked and will not close. Could you please advise if the control panel has any lights lit up on it? Also, may I have the model number of your dishwasher? You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. With this additional information I would be able to assist you further. -Matt
SOURCE: Door latch in closed position
put two small screwdrivers in each side of the latch and lever upwards (best way) or otherwise take the door outer panel and fascia off so you can get at them
to stop it reoccuring, bend u catch on cabinet slightly downwards
SOURCE: Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
SOURCE: Dishwasher latch handle is stuck in closed
I had the same problem and with some pushing and pulling I got the door open again.
TURN OFF THE BREAKER....
Next take all the screws out of the door panel to access the door latch assembly. You will see the handle has plastic tabs that hold it in place which are broken. Order a new assembly and install it.
My problem was getting the wiring harness off of the switches they are clipped on very tightly so I just kept the old ones connected and put them on the new assembly.
Good luck
O
SOURCE: samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Testimonial: "thanks, ill try that now"
