Question about Razor E300s Electric Scooter With Seat
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
I bought two E300s about a year ago. I already replaced the batteries once. I replaced the motor in one and it ran very slow. The problem I was having was it would run for 15 minutes and then would get very slow. It suppose to run for 40 minutes continous. I called razor said it was batteries replaced them. MOtor replaced still can't get it to run for 40. But it I let it rest for half and hour with out charging is runs fast again for another 15 minutes. What is wrong wit it????
  • Walid Zubair
    Walid Zubair May 08, 2017
    The relay on the controller is faulty, change the controller.
    Habit-Forming:
    New Friend:
  • 139 Answers
It will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Posted on May 21, 2017
SOURCE:
  • 7 Answers
SOURCE: razor e200 runs slow
you need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
drifterK
  • 4924 Answers
SOURCE: Bought a new battery for
take a look at the other one and see on which side the wire was hooked..on +or - or both where ...and just get some wires if they need to be longer ..and hook it in the same screw with the normal power line ..but remember from the other one ..which and where ..
Posted on Aug 25, 2010
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
  • 45 Answers
SOURCE: I was given a Razor E300 and was told that the
You have to make sure that the batteries are still good.
Take a volt meter and read the levels that the batteries are producing. If the levels are too low, then your batteries may have sat, unused, for too long. SLA (Sealed Lead Acid) batteries will generally lose their charge holding capabilities if you leave them in storage for too long without charging them.
YOu can get replacement batteries at this online Electric Scooter Parts Store:
http://www.partsforscooters.com/s.nl?partner=URBANSCOOTERS
-Jackson
http://urbanscooters.com/
Posted on Nov 25, 2010
  • 45 Answers
SOURCE: My sons razor E300 duns only at about 2 mph on a
You can diagnose your scooter's issues with a volt meter.
test the batteries and make sure that they are putting out sufficient voltage/amperage.
Test the Throttle to see if the regulator is working smoothly.
Test the Controller to ensure that it is working properly, as this is the scooter's "brain".
Check the fuse(s) to ensure that you are connected, and also check wiring for broken, shredded, or burnt wires.
Most likely you need new batteries. If you leave SLA batteries in storage for too long, without use, the batteries lose their charge holding capabilities. SLA batteries hold a charge through a chemical reaction in the Acid Liquid in the batteries. If the chemical reaction settles, the batteries will not accept a charge anymore.
Generally, you don't want to leave SLA battery powered scooters unused for much longer than 3 weeks. :)
-Jackson
Razor e300 Continually needs to be reset continuously need to restart my e300 because stops, only has 2 week old, initially worked perfect, then reset again run until stopped again.
I posted a similar issue about the same scooter. If you do replace the batteries and still experience the same issue, check the wiring for loose wires and possibly replace the fuse.
After replacing the fuse and connecting wires, my scooter doesn't pop the fues with every use anymore.
http://www.fixya.com/support/t7752702-ride_scooter_turns_off
Feb 07, 2014 | Razor E300s Electric Scooter With Seat
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
I bought my Zune 2 years ago and thought I had lost it, but found it. So I have been using it for only 1 year. About 2 weeks ago even after charged, it will only play off the charger for about 45 minutes....
Debbie,
Zune batteries are replaceable. They can be purcahsed for about $10-$15 and with a little knowledge can be replaced by anyone. Check the internet for both the battery and replacement instructions. eBay is a great place to find the battery and most places even include the needed tools
Nov 25, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
When i charge my e300s for 8 hours and plus. And when i ride it the battery goes back to low in 2 mins pls help.
Hi and Welcome to FixYa, I am Kelly. You did not mention the age of this scooter or an estimate of the hours it was used. This sounds like the plates in the battery have deteriorated to the point that the battery must be replaced. Old batteries will self discharge do to corrosion or multiple re-charge residue that causes internal battery plate shorts or there is no longer enough plate material to provide the amperage necessary to operate your scooters motor. The only remedy is to replace the battery. If it is relatively new... then there can be a short in the chassis wiring. I doubt there is a short in the wiring as the controls seem to be functioning normally per your comments.
I have over 40 years of real world battery experience autos, aircraft, battery packs et al. This just sounds like the battery life has been reached and the battery needs replaced.
Thanks for choosing FixYa,
Kelly
Nov 14, 2010 | Razor E300 Scooter
My Ebel (9187241) is now 11 years old. Recently...
The 4 second ticking indicates the battery is in need of replacing.
A professional watchmaker can properly replace the battery for you.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 20, 2010 | Ebel 1911 1087221 wristwatch
2001 Camry Often Won't Start When Hot Outside Unless Jumped
well is the battery draining over the time its sitting?
could be a bad battery or alternator, and/or you might have something on the car constantly draining power from the battery.
best to have it looked at by a mechanic.
Aug 09, 2009 | 1994 Acura Integra
Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
May 31, 2009 | Polaris 800 Twin Sportsman Ride on Toy
Heater will not stay running
bigrench1843@aol.com. I just fix this same problem 15 min. ago after 2 days of headbanging
915 EST. lets talk
Jan 28, 2009 | Reddy R155D Utility Heater
Kodak C643..what is wrong?
i bought some nimh rechargeable batteries a couple years ago and they still work to this day. im on my second camera with them and it does that to me when the batteries are dead. try opening the battery door when it does it and then close it and try turning it on again. if it does come on then its the batteries.
Aug 30, 2008 | Kodak EasyShare C643 Digital Camera
SCC 658 Runs way too hot
I bought mine about two years ago. Had the same experience as you did ... it is not working right for a slow cooker. After my first disaster with it, tried making something again and insuring it was filled all the way. Burned all the food again. Now it just takes space in my cabinet. I bought another slow cooker that just the basic 3 position knob, no electronics.
Jan 21, 2008 | Rival SCC658-SS 6.5-Quart
Razor E300s  Electric Scooter With Seat Logo
610 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
