Hello Avishag, thanks for your post!
From what you have described your Electrolux oven is ringing after you have used the pyrolytic cleaning. Your control panel may need to be reset and you can do that by disconnecting power from it for at least ten minutes. If this does not help resolve your issue I would need your model number to further assist you. You can locate that information on the frame of the door on a white or silver tag. Once I have that information I would be happy to assist you further. -Matt
SOURCE: Can't use my Meile pyrolitic oven fault 90
I turned it off at the main power source and then turned it on again and it worked just fine ... no further problem. I would have been mad if I had called a serviceman and had him lust throw a switch and charge the earth !
SOURCE: The self-cleaning cycle on our oven stops mid-cycle
I would never use the self clean in the first place...it causes many problems. I see many problems on Fixya everyday because of this feature...
Check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
SOURCE: I have a UMP 404 de dietrich oven user manual
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
SOURCE: use the pyrolitic oven clean setting, finished
some times unpluging the unit and waiting 5 mins and powering it back up will reset the unit and unlock it
SOURCE: Damage to lining of Pyrolitic oven
I have a hotpoint, am currently on my fifth oven and this too needs replacing. The pyrolitic lining is flaking off and going onto my food. It's coming off the roof as well as the walls so is not just from impact with trays.
