HP Officejet Pro 8610 Wireless All-in-One Color Inkjet Printer A7F64AB1H Logo
R
Robin Posted on Apr 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have followed the instructions that came with the printer but when we put in the password for the wifi, it does not connect to the Internet.
If we cannot connect to the Internet, HP will not know when to send more ink cartridges.
kkirkpatrick baker
Level 2:
Sergeant:
  • Expert 313 Answers
  • Posted on Apr 29, 2016
kkirkpatrick baker
Expert
Level 2:
Sergeant:
Answers
313
Questions
Helped
83173
Points
637
Follow the printer instructions in your manueal ur printer looks like 8600 pro or newer 8620,8630 I have no problems with my password I do have 8600 pro call hp they will walk u thru it complete
5 Related Answers
Evilsmith
Eric Smith
  • 26 Answers
  • Posted on May 07, 2008
SOURCE: hp deskjet 842c blinking ink cartridge light
You have to take off the clear strip of plastic over the copper area, or the printer will not detect it. There should be a green pull-tab on the cartridge.
A
Anonymous
  • Posted on Jun 25, 2008
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
Anonymous
  • 180 Answers
  • Posted on Mar 07, 2009
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Anonymous
  • 73 Answers
  • Posted on May 26, 2009
SOURCE: Printer Reset instructions for HP 564 inkjet cartridge.
Dear, this is basically an auto generated message based on system registery keys, if you want to bypass the message, then there are two ways.
1. put another cartridge in the printer and try to print, after than install the previous (original) cateridge, this will doge the printer as a new cateridge, you problem will be removed. but if you don't have another similar cateridge at hand then follow the step 2 given below.
2. Uninstall the driver, unplug the printer, restart the system and reinstall the printer dirver again, your problem will be removed.
Best regards.
Anonymous
  • 15 Answers
  • Posted on Jul 13, 2009
SOURCE: Printer will not recognize refilled black HP cartridge (#74)
Try to get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Please post if that worked.
1helpful
2answers
Trying to connect wifi to hisense smart tv ssid wifi connection. I put in the password for access point connection and it either says timeout or connection failed. Any suggestions?
plug in the eithernet cable while you try to connect the wifi and after it's working remove cable and try the wifi, I have a printer where the cable needs to be connected while installing the wifi and after working remove cable and works fine..
My printer is not working with my desk top are my lap top computer.
A wireless printer needs the WiFi password just like any other WiFi device such as Laptop or iPhone. The WiFi password or key is usually written on the underside of the router. If the printer as a little screen then you can take it to setup mode and select the WiFi signal and enter the WiFi key. After that your computer can seek the printer. You may want to run the install software again.
A different way to do it is run the install software on the PC with the USB connected between the printer and the PC. Follow the on screen instructions, similar to above and once done you can run the printer wirelessly.
I am trying to get wif on my samsung galaxy it tells me get guest password can you help
You would need to refer to your Belkin's instruction manual for how to set up WiFi on it. The password for any WiFi hot spot is unique to that hot spot so there is no general 'guest' password per se - it depends on how you setup the WiFi router.
WiFi routers also have a web-based interface where you can open a browser from a connected PC and manage the device. Again, the device's instruction manual will tell you how to do this.
If the router was supplied by your internet service provider you should be able to call them for help.
How do I access the WiFi Internet Connection With Tablet
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
How do I connect my Nexbook 8 to the internet on my laptop
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Need password for 31803-4420A4FDE881EG
are you pertaining to your wifi password?
for you to have access entering the modem/router settings you will encounter 3 sets of username and password:
*modem access after 192.168.1.1UN: adminPW: admin
*PPPoE access:UN: is to be provided by your internet service providerPW: should be provided by them as well
* wifi settings:JUST follow these instructions for the wireless access
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Please help me i cant get on the internet on my hand set ???
DO YOU WANT TO CONTACT INTERNET THROUGH WIFI OR GPRS?
ANY WAY IN BOTH FOLLOW THE BELOW INSTRUCTION:
MENUE - ALL SETTING - WIRELESS CONTROL
1- AFTER INTERANCE YOU MUST TAP ON " DATA CONNECTION " FOR GPRS ON.
OFCOURCE THIS RELATETED TO YOUR NETWORK PERMISSION.
2- FOR WIFI YOU CAN TAP ON " WIFI " STCTION . IN THIS CASE YOUR PHON TRYING TO
SEARCH YOUR " WIFI " WHICH YOU USE IT IN THE NAME OF WIRELESS ON YOUR PC
AFTER FOUND , TAP ON YOUR OWN WIRELESS WHICH SHOWN WITH SOME OTHER
WIFI WHICH IS IN RANGE.... OK AFTER TAP ON YOUR OWN WIFI , THE PHONE REQUEST
YOU TO INTER THR PASSWORD " THE SAME PASSWORD WHICH YOU INTER IN YOUR
WIRELESS OF YOUR PC . AND ASK YOU TO CONFIRM IT AGAIN .
BE CAREFUL TO MENTION THE PASSWORD SAME .
THEN THE ABOVE OF YOUR PHONE SHOWN MARK OF WIFI ACTIVITY .
NOW YOU CAN REFER TO YOUR BROWSER AND USE OF INTERNET .
GOOD LUCK
gorbesia
2answers
Issue: I have a Canon Pixma iP6220D inkjet printer and it will not connect to my computer wirelessly (my computer does not support Bluetooth). Query 1: What type of wireless technology does the printer...
1) This particular printer is available in versions that connect via Bluetooth or via Infra Red. There does not appear to be a Wifi version. 2) To get it to work via WiFi, you'll need PC with Wifi and 3) a Wifi print server like this
Amazon com TP LINK TL WPS510U 150Mbps Wireless Print Server USB 2 0...
k24674
Grand Canyon Tech
Grand Canyon Tech
