Ensure you replace the filter on the AC or
How to clean filter of split AC
When its turn off,not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
SOURCE: Sir, I would like to
you have to remove the front cover to access the filter. The cover should be held in with push button retaining clips. After you remove the cover the filter resides in front of the evaporator.
SOURCE: hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Put your AC on Standby mode then press the filter key...let it stay till AC shuts automatically....once AC shuts press filter key again to switch it off.
Thank you very much..it worked..lots of love and blessings.
