Hello Tasha, thank you for your submission!
I understand that your Frigidaire washer stops for a minute then begins to squeal. I see in the picture you are looking at the rear bearing or spider arm on the back of the tub. I would recommend having a professional technician out since you stated that something may have been broken during moving or disassembly. This will help prevent any unnecessary part purchases. I hope this information is helpful. -Matt
SOURCE: Frigidaire FWTr445rfs1 front loader - door closed but buzzes during washing
by the way it too fixya over 14 hrs to relay that message
SOURCE: Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
SOURCE: loud banging noise during spin cycle on front
Could be a broken spring on top of the drum allowing it to hit back of casing...hope you fix...
Hi Tasha Davis-Burns, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what model number
