Question about Dell 1815dn All-In-One Laser Printer
Dell 1815 prints every page blank. Two diffient toners have been checked.
Hello it looks that laser didny fotoconduct drum. How to check that is laser or logic ? Greetings Michal
    Habit-Forming:
    New Friend:
  • 64 Answers
Do you have a toner error sign?
Posted on Apr 09, 2016
Testimonial: "No - toner is ok, no toner error."
SOURCE:
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
My printer canon ir 2022 prints faints and blank pages, what can be a problem and how to fix it?
first You must check, if the image is on the drum. To do these, start print and when you hear that paper is in drum section open the left door and look at the drum surface for the toner image on it.
i.e.
If the image is on it and it looks solid, check the transfer roller or replace him. Also clean the laser unit ( lenses and polygon mirror ) and change the drum unit. It can also be the problem with toner station.
i.e. the cylinder doesn't turns or the there isn't toner on cylinder.
It can be a bunch of things, so without seeing the machine it is difficult to say what is the problem... but, in most cases, the problem is in dirty laser unit or in transfer roller.
May 02, 2011 | Office Equipment & Supplies
Toner is printing on right hand side of each page printed
Most likely it is the drum cartridge. The other causes such as toner on the laser optics would not produce an on again off again print area. It would be blank the entire way down the page. Since the toner prints in patches down the right side it means it is coming from something that is "rotating" and that narrows it down to the drum.
Good Luck and Thank You for using Fixya.
Mar 31, 2010 | Dell 1700 Laser Printer
Dell 3100cn printer leaves a blank strip
The following table should help
Contamination in the laser path - 1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
Defective fuser - Replace the fuser assembly.
Lack of toner or faulty toner cartridge - Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
Dirty Corona Wire - Clean the Corona Wire.
Defective Drum - Mostly applies to B&W printers. Clean the drum or replace the drum.
Sep 20, 2009 | Dell 3100cn Laser Printer
Copies are coming out with a faded or blank patch in the centre of the page
Check the toner cart and the drum is it old/new is the toner cart properly installed. Is the LASER glass clean it should be protect by a cover ensure machine is off when checking and cleaning the LASER **** glass. Also check if you can print out a machine developed document such toner/pages printed document to see if this problem is related to the scanner or the drum/toner/LASER, if these document print out clan then the problem is with the scanner
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 09, 2009 | Canon PC-940 Black and White Copier
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Dell 1600N MF Laser Printer- Blank vertical strip on all prints
you need do follow steps:
1) take out the cartridge find a cover there is the drum inside, the drum you can see the color on the drum surface
2) check out and clean any pieces of paper or dirty waste toner stuck there, because there is a waste toner cleaner on the drum surface which is like a long rubbon strip (something like that) you can spin anyway a little to clean.
3) if you check out any different color (vertical round drum), that is the drum surface worn or scratched. you can see the worn area show light color than normal area.
so you need change it better. 4) if the color all very same and still not fix, you need check again something stuck the drum surface near cleaner rubbon.
hope help you fix it, please take a rating let me know how much helped you thanks! keep in touch your question please.
May 21, 2009 | Dell 1600n All-In-One Laser Printer
Print error
Replacing the drum should fix this issue. The PC drum, aka, photoconductive drum, is light sensitive, if it has been exposed long enough to light, it can cause this problem.
Jun 19, 2008 | Dell 1720dn Laser Printer
Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Nov 08, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
