If the bike has a coolant system and the oil is milky, yes it is a head gasket that is bad. You can use a cylinder leak down test of a compression tester to isolate the cylinder.
Nov 23, 2009 - 11 posts - 8 authors
On my 2007.5 Duramax, the factory remote has been working fine ... I tried this morning again with the remote starter while sitting in the truck and same thing, turned off ....2008 Silverado 2500 HD CCLB Duramax 6 Spd Allison 4X4 Z71 ... shut off engine", basically its doing it foryou as your not in the truck to ...
check engine light on wont shift
Oct 28, 2011 remote start
Oct 14, 2008 More results from www.dieselplace.com
car needs checked for cold start in the computer ..unless other underlying conditions are present like all the fluids up?..the computer will sense an issue and cause the system to shut down(rather that total malfunction..)
If you do not refill the filter housing after replacing the fuel filter there is another way to refill the housing. after the filter is replaced and the cap is secured turn the ignition to run for about 5 seconds then turn to off. again turn to run for about 5 seconds then turn off. Repeat this about 8 to 10 times and then start the engine. What happens is that every time you turn the ignition to run the fuel pump attempts to pressurize the line then shuts off. That is why you have to repeat the process. While the truck is running the power to run the fuel pump comes from ecm. Some kind of safety function Dodge has built into the system so fuel will not continue to run if the engine is shut off.
