Subaru 2005 Outback 2.5 XT Limited Logo
Troy Krawiec Posted on Apr 08, 2016
Tail lights turn on instantly with the key on and the head light switch off also with this the cruise will not work
2 Related Answers
Anonymous
  • 180 Answers
  • Posted on Mar 11, 2010
SOURCE: tail lights won't turn off
Check the parking light switch on the top of the steering wheel.
Jason Snedigar
  • Posted on Jun 26, 2012
SOURCE: lights stay on with key out
I have dealt with similar issues in a couple of other vehicles, most recently in my own wifes car. Inside the dashboard of most late model cars, in the general vicinity of the stereo/nav system, or computerized components is the electronic brain of the vehicle, and there a a series of power relays, regulating the distribution of power to components inside and on the exterior of your vehicle. So imagine this part, under constant use for a number of components on and in your vehicle being used just as much if not more than anything else in the vehicle. With that said, many manufactuers have different names for the part, but the part name I have dealt with over the past 2 repairs is " Computerized electronic control module". Hands down the smallest, most delicate part I have ever had the joy of replacing in both vehicles. The part in both repairs were not cheap, I found 1 for a 2007 V.W. Jetta at a scrap yard, luckily, for $380.00, but it retailed at a dealership here for just under $1000...Holy S%^#!!! And the second was on an 2009 Acura TL, both were tricky to get to, mainly because so much has to be removed to access this part, and they both sat nesstled in the tiniest of cradles.
If you do not have much experience in dealing with tiny, delicate electronic components, or do not feel comfortable working on vehicles and tight places with the chance of smashing knuckles, ect. I would recommend you pay the cost of having a repitable, accredited mechanic, one who may even specialize in foriegn makes and models, and may have electrical work somewhere in their title, do the work under warranty.
There is know price or cost on the value of "Peace of Mind"
P.S.
If these are the only 2 symptoms you have as of now, consider yourself lucky, and it can and will get worse as the problem persists without repair. I.E. Window power failure, stereo/audio, nav failure, wiper failure, display light failure, dome lights, power locks....and so on.
Good Luck,
Jason
Head lights, tail lights and dash lights won't come on.replaced head light switch but didn't resolve problem
Not the turn signal switch if the dash is out also. Check the fuse for the dash/illumination first. If good, then you have a power or ground problem to the switch. If bad and they come on, replace the turn signal switch.
Day time running lights and tail lights wont turn on
Here you haven't mention your cruise model name, Go to the given link which is online store known as reliable, they have repair manuals, I am sure you will get the solution
cruise
2005 ford escape rear tail lights stay on
Sounds like the brake lights are staying on, which is probably a faulty brake light switch on the pedal.
2helpful
1helpful
I have a 97 nissan pickup and the head lights will not turn on, an the tail lights will not shut off. had to take fuse out to turn off tail lights. turn signal switch??
Yes it sounds like the switch is stuck in the park position.
You could pull the harness plug for the switch and check the circuits with a meter, or replace the switch.
1991 GL1500A no lights,no crank
Sound like the main dog bone fuse locate to the front of the battery under a protective cover has blown. Always carry spares.
How do I install my intergrated tail light with turn signals i got the tail light to work but the stock turn signals have about three wires each
The stock turn signals have 3 wires1) Positive for turn signal2) Positive for cruising light (comes on with the light switch's 1st click)3) Ground.Obviously you can either replace the entire turn signal with the aftermarket one and stop using the cruising light or bypass the positive wire for the turn signal only, to the aftermarket one, and leave the original turn signal with the cruising light only.
3answers
Both Tail lights and dash lights are out. Fuse is OK
I have the same car and had the same problem, these cars are notorious for the head light switch to fail.
4answers
Headlights
If you already check the dimmer definetly you will have to remove the dashboard area where the indicator is and replace those light bulbs they are tiny so careful and first check your auto parts store for correct number.luck!
Top Subaru Heating & Cooling Experts
Paul Carew
john h
Are you a Subaru Heating and Cooling Expert? Answer questions, earn points and help others
