How do i retrieve the bobbin thread to the head thread
The first thing you need to do is check with your user's manual on to make sure that your needle is inserted correctly--flat side to the back, and it is all the way UP in the holder. I find a small needle nose pliers helpful to hold the needle for this. If you don't have it, you can download it free at the Singer Sewing machine website--I just did before I answered this.
Next, make sure you have correctly threaded your machine, and when you did so, the presser foot was UP (ALWAYS thread with the presser foot UP--on ANY machine anywhere!).
The next part is on page 20 of your user's manual, and there are drawings. Then, insert your bobbin, with the lever on the case DOWN (it's the only time you can insert and remove a bobbin; with the tab on the case open, the bobbin is locked into place. Make sure the bobbin is inserted the correct way. In your case, when you hold the bobbin up vertically the thread should be unwinding from the left, or clockwise. After you have inserted the bobbin, take a look at the right side of the bobbin case towards the top; you will see a slot the thread needs to go into. Once it's in the slot, hold your finger on the bobbin so it that can't unwind, and pull the thread so that it is in the slot at the top of the shot you put it in. This part exerts tension on the bobbin thread, and it's VERY important that you get it in there. . Then open the tab or lever and put it into the bobbin basket (holds the bobbin case), with the projecting part on the top. A length of bobbin thread should be projecting outside the case at this point--you will be drawing it up to the needle plate.
How, hold the top thread end pull the hand wheel TOWARDS you (ALWAYS towards you--on any machine) at least one revolution and possibly two revolutions, then pull on the top thread and the bobbin thread will come up. When starting to sew on fabric, hold your hand on the top thread for the first two or three stitches.
