Washing Machines Logo
How can we fix e2 error in super general SCW640
1 Related Answer
Anonymous
  • 15935 Answers
  • Posted on Sep 29, 2010
SOURCE: RF364 Electric Kitchen Range: my whirlpool super capacity 365 is showing E2 F3 (...
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#
2answers
Super General Refrigerator Error E5 issue?
Question edited for a lot more clarity and for spelling.
Question moved from Super computers category.
Are you sure it it a refrigerator and a refrigerated AC unit?
Super General AC error code e5 "E5" - Fan Motor Problem: Occurs when the over current from the fan motor is detected. Solution: Verify Power (Voltage/Amps).
Common Portable AC Error Codes - Priority Rental
https://www.google.com/search?q=Super+General+Refrigerator+Error+E5
Super General Split Air Conditioner 2. How to fix Super General Inverter A/C with P2 error code please?
Question edited for clarity.
How do I fix P2 error in AC?
If the P2 or FL error code is displaying on the air conditioner, remove the drain port cap and tilt the air conditioner to the back so the water runs out of the drain outlet. If no water is draining out when the air conditioner is tilted to the back, the unit will require a repair service.
Dec 11, 2018
More here and videos
https://www.google.com/search?q=super+general+inverter+ac+p2+P2+error+code
Sorry my ac show me error code e3 type super general model sgsi188-i5
Error code E3 on a Super General air conditioner model SGSi188-i5 indicates a communication error between the indoor and outdoor units. This could be caused by a faulty control board or a wiring issue.
You may try resetting the air conditioner by turning off the power supply for a few minutes and then turning it back on to see if the error code disappears. If the error code persists, it is recommended to contact a professional technician to diagnose and fix the issue.
Super General 7 kg fully automatic Top-Loading Washing Machine SGW-721. It has E error on it.
Question edited for a bit of clarity.
This doesn't appear to be a General Electric (GE) machine and looks to be an Arabian machine. We are in North America. This link might work better for you in your county.
https://www.google.com/search?q=super+general+automatic+washing+sgw721+e+error+code
Error code F3 /E2 on Whirlpool Cabrio Dryer.
Question moved from Cars and Trucks.
The Whirlpool washer F3E2 error code is a temperature sensor error. You can check the temperature sensor with an ohm meter to verify the sensor is bad. ... The correct ohm reading should be between 500-100K ohms, if not the sensor is bad and needs to be replaced.
Whirlpool Washer F3E2 Error Troubleshooting and Repair
2answers
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
1helpful
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
