HP L7680 Printer Head Problem
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Step two:
Increase the print quality mode
If
reprinting did not help, try increasing the print quality mode.
In the
application you are printing from, click File, and then click Print. Make sure
the printer is selected, and then click Properties.
Select the Paper/Quality
tab. In the Print Quality area, choose the next higher quality setting. If the
current setting is Draft, choose Normal.
If the current setting is Normal,
choose Best.
Step three:
Print in grayscale (black area streaking only)
If the
streaks are in a black area of a black and white printout, change to grayscale
printing.
NOTE:- This
step does not apply to color printouts.
In the
Make sure
the printer is selected and click Properties.
Click the Color
tab, and select Print Grayscale and High Quality.
Step four:
Clean the printheads
If the print
quality is still bad, clean the printheads.
Make sure
the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings,
Print Settings, and then select Printer Toolbox.
Click the Service
Tab.
Click Clean Printhead,
and then click Clean.
Step five:
Align the printheads
If the print
quality is still bad, align the printheads.
Make sure
Open the
printer Toolbox, and select the Printer Services tab.
Click Align Printheads.
The Align Printheads window opens. Click Align.
The printer
prints an alignment page. The lines in the patterns should appear to be
straight. Click OK when the page finishes printing.
Step six:
Calibrate the linefeed
If the print
quality is still bad, calibrate the linefeed:
Make sure
Open the
printer Toolbox and select the Printer Services tab.
Click Calibrate
Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven:
Replace one or both printheads
If the print
quality is still bad after performing all the above steps, one or both of the
printheads will have to be replaced. Print a PQ Diagnostic page to see which
printhead should be replaced.
Make sure
Press the Setup
button.
Press 1 and *
simultaneously.
Look at the
color blocks labeled Test Pattern 2. Some or all of them could show white
horizontal streaks. If none of the blocks are streaked, the printheads are
okay.
If the Black
block has lines – replace the KY printhead.
If the Cyan
block has lines – replace the MC Printhead.
If the
Magenta block has lines – replace the MC Printhead.
If the Red
If the Green
