SOURCE: CUB CADET
Look under the battery holder. There is alot of wires that come down from the ingition and the fuse should be mounted or fastened right under the battery holder.
SOURCE: I have a 2005 Cub Cadet Series 1000 LT 1050 with
Sounds like the drive belt has been thrown off of the drive pulley.
It is fairly simple to identify the drive belt. - it is the one that is connected directly to the pulley coming donw from the motor... and it travles over a tensioner pulley (that you control with the clutch) and then over the large pulley that is mounted over the transmission.
Check to be sure that the belt is ON the pulley... and not broken..
-Jim
SOURCE: Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
SOURCE: cub cadet 1050 fuel problem
Hi, I found manual on amazon, so you can check there for solution: International Farmall Cub Cadet 1000 Operators Manual Paperback July 20... I hope I have helped. Cheers
