1# IF THE WOOD STOVE IS INSIDE YOU NEED AN EXHAUST SYSTEM IN THE HOME.
2# IF THE WOOD STOVE IS OUT SIDE AND THE WIN IS BLOWING IN THE DIRECTIOM TO THE HOUSE THEN THE SMOKE WILL COME IN THE HOUSE SO! IS NOT THE TYPE OF WOOD YOU BURN.
I see that your Frigidaire refrigerator, model# PHT219WHSM1, is still leaking from the filter, even after you changed out the filter and o ring. First, I would check the filter for any cracks. If there are cracks, I wold see about maybe returning the filter. If there are no cracks, there could be something going on within the filter housing. I suggest contacting a local authorized technician for further assistance.
Clean the entire lint parts even the hose in the back and male sure the hose isn't open side Dow under house. Air isn't escaping had same problem. Turns out the house was straight down n the dirt under the house
A blocked exhaust pipe will do this. Possibly just the catalytic is plugged, but you make it sound worse than just that.
Disconnect the exhaust at the manifold then start the engine, see how it behaves. If it revs up (loudly) you know it the exhaust system. Consider the neibours too. Do not run the engine for any length of time like this as you can damage valves when they cool too fast.
If it revs freely 2 - 3 times, then take to an exhaust shop for service. Or do it yourself?
Good luck
There should be a alarm by-pass (red button under the dash) located on the drivers side above the brake or clutch (if equipted) peddle. Opening the door (as you probably already found out) will set the alarm off, so it's a good idea to let you neibours know what you are doing so the police are not called on you. Once pressing that button, the alarm and the ignition lockouts will be off and will need to be reset before you can arm it again.
