David Pritchard Posted on Apr 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What cable do I need to connect to non-wirwless computer
WTF Chuck.....
Level 3:
  • Master 388 Answers
  • Posted on Apr 06, 2016
WTF Chuck.....
Master
Level 3:
Answers
388
Questions
Helped
98628
Points
1224
Hi David,
I'm going to assume you're trying to connect a printer to your PC...
If you are, it should have come with the cable already...
most wired printers today come with and use this type.
what cable do I need to connect to non-wirwless co - 26154594-xdyygz2jnmsnxs0f22zxdtmj-4-0.jpg These can be bought at any electronics store, and are pretty cheap.
Hope this helps!
Please rate!
Thanks,
Gary
cdcra
Level 1:
Habit-Forming:
New Friend:
  • Contributor 18 Answers
cdcra
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
18
Questions
Helped
6858
Points
56
tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 • Computers & Internet
I have linksys 2.4 ghz + one 12' line. My new computer is in another room, 32 feet from cable modem how do I connect to internet?
I'm assuming that one computer isn't wife enabled. Depending on where the non wifi computer is located in relation to the router, you will need another either patch cable or a wifi adapter.
I was trying to set up wireless broadband connection on my
If you have forgotten your WiFi security password, you should be able to reset your router via a tiny/recessed push switch. Then you will have to set it up again.
Is lbp 290 a wirwless printer??
This model printer does not have a wireless connection.
1helpful
2answers
What type of cable should I use to connect camera Vivicam.10 to laptop computer running on XP
In order for you to connect this camera to your computer you need to have a USB cable that will be connecting the camera and computer for the file transfer. You can get a USB cable from any computer store.
1helpful
I have a linksys wireless-b 2.4ghz 802.11b and it dont like my ro
when you try to connect to the wireless network , do you see your network ?
What is the operating system on your computer ?
Is it windows XP ?
If it is windows XP then try to use windows utility to connect to the wireless network ?
Click here for more instructions about the wireless network
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
3helpful
2answers
Hard drive recovery, hard drive is damaged
Hi trouble67,
Geek Squad® offers data recovery services. There are three levels of data recovery available, dependant upon the condition of your hard drive. For more information, visit your Geek Squad® precinct at your local Best Buy™ store. You may also check out other Geek Squad® services at http://www.geeksquad.com/pricing.
Thank you,
Jason,
Go Ahead. Use Us.
k24674
ADMIN Andrew
ADMIN Andrew
