Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Bob Gerwing Posted on Apr 06, 2016
Canon mp530 fuse is located where? - Canon PIXMA MP530 All-In-One InkJet Printer
picipolman
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Apr 12, 2016
picipolman
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
13576
Points
23
Underneath the printer there is a removable power supply in a relatively small box - it has a fuse :)
Canon mp530 one twain
All of the drivers, software, and utilities are available at the official Canon website. The link is attached below. Canon Support Drivers PIXMA MP530
1helpful
3helpful
Canon Pixma MP530 died while printing. No error msg. Dead, no lites, no response to off/on button. Examined the circuit board into which the 120V power connects, but cannot see any fuse, and Canon Tech...
If you have a multimeter check for voltage behind the transformer, check the power button is still operating correctly.
Also it may have a non-serviceable fuse that wont be listed by canon, they will charge for a whole circuit. Check the continuity of components directly after the transformer. one of these may be blown.
Hope this helps
GM
2answers
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
Where is the serial number on a Canon PIXMA MP530 multifunction printer?
The serial number of the PIXMA MP530 is located inside the printer, as shown below.
  1. Lift the Scanning Unit (Printer Cover) until it locks into place.
  2. When the printer is powered on and the Scanning Unit is lifted, the Paper Output Tray will open automatically. If the Paper Output Tray does not open after several seconds, press the Open button to open the tray manually.
  3. Open the Inner Cover.
    The serial number is attached to the back wall inside the printer.
    It starts with four letters (AAGA) and ends with five numbers. Example: AAGA01234
2answers
I need Canon MP530 manual
http://www.retrevo.com/support/Canon-MP530-Multifunction-Printers-manual/id/1071dj296/t/2/
old marine
old marine
ZJ Limited
ZJ Limited
