Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
The connection should be the cable box out to the DVD in, the DVD out to the set. The DVD should have a channel select, Either 3 or 4- set it to the channel that is not used by the cable decoder. which should also have a switch for 3 or 4.
Then all you do is switch between channel 3 or channel 4 with the TV remote or by TV channel buttons. One will be cable, the other will be the DVD.
When you have just the cables as you describe, you are using composite inputs. By default, yellow is video, red is right audio, and white is left audio.
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Check Carefully on the Back on the DVD You will see different color RCA plug yellow, Red and white Input and Output The yellow output from your DVD go on the input TV ...Then the red output go in our red TV input Same for the white RCA plug sample to do ...
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
there are three cable yellow red and white your yellow
cable is the picture cabe and your red and white cabe is the sound cabe plug the yellow cabe in the yellow input and the white and red in the red and white input @ the back ok you recorder now the some go to the tv set it will work 100% now
Your problem is that your TV has no video inputs. TVs use those red white and yellow plugs to transmit the signal via those cables. By cable box - do you mean a digital box? You can't run it through that unforunately - those connections are only for the box itself and it only has an output.
You'll have to go either: Buy a new TV or get an RCA Modulator.
