Http://www.hardreset.info/devices/nokia/nokia-2330-classic/
Hi Peter, you will have to call your Carrier your phone is registered with as it sounds like an operator error. Some configuration on their end has prevented you from sending messages.
Last resort is to reset your phone using the above link. (this is a last resort in case your carrier won't help as it will reset ALL your settings and restore it to factory default) I would call them first and see if they will help you.
SOURCE: My Nokia N73 cant recieve text messages, it can send but cant receive.... :(
Hi.
I have had the same problem with my nokia N73. Please check your SMS center number if it corresponds with the network you using, and that it has the complete digits typed in. And also, try to communicate with your network oprator to get your SMS center number. Good luck
[email protected]
SOURCE: unblocking
mate if its under 2 years old you can take it to any carphone warehouse or phonebox comms for testing free of charge...
if it is blocked(blacklisted) it is pretty much useless..
SOURCE: nokia 6300 canot send text message
Hello there! thanks for using Fixya.com!
Kindly check the message center number from your mobile phone if its already there or you can contact your Network Service Provider to provide you the specific and correct message center number. Usually, you don't have to touch these numbers. If you suspect they are incorrect, contact your mobile service provider and ask them to send an Over The Air (OTA) message with the correct information in it.
Please be informed that the SMS Message Center Number is a phone number that acts as a gateway for transferring SMS messages between cellular devices.
Some tips!!!
Where are these numbers stored?
Hope this will help!!!
SOURCE: cant send text messages but can recieve text
Do a reset on the phone. Power down and then power it back up. If that is unsuccessful, you need to go into menu settings under message settings, then make sure that receive messages is set to allow.
SOURCE: I never recieve texts until
goto settings>Phone>application settings>log
set the log duration to 30 days..bingo..
