Pride Go-Go Sport 3-Wheel Scooter Logo
I
Irene belisle Posted on Apr 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn it on an alarm sounds and won't stop. The scooter works well except alarm won't stop. It is as if you are pushing on the horn all the time.
It sounds like you're pushing the horn constantly.
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Apr 05, 2016
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
518142
Points
3838
Hi Irene, sounds like you got water inside the button you push to activate the horn, the push button will need be dried out ....either by disassembly's or carefully placing a warm setting hair-dryer near the button and operate to get the water to evaporate .. but don't do it too hot otherwise the button will start to melt...
Regards
Rob
  • Anonymous Apr 06, 2016
    A tech said that another reason was that something pressed on the button and a wire broke.
  • Rob Hill
    Rob Hill Apr 06, 2016
    the wire breaking would not trigger the horn unless the wire or wires are touching all the time...
Scooter alarm won't turn off -Go Go scooter
hi, sounds like there is water in the horn button, it settles at the bottom and causes the button to conduct, like you pressing it down, so carefully take a hairdryer and warm the area around the button, remember it's plastic and it will deform if it gets hot , the trick is to feel the plastic making sure it doesn't get hot , don't hold the hairdryer too close. the warmth will dissolve the water and the horn sound will stop but it won't happen in five minutes and depends on how much water has got in there , another trick is to put the scooter upside down and work the button, this will cause the water to slowly run away, but you must remove the battery pack...so take care ..
so if you're using a hairdryer be careful you don't melt the plastic ...
regards
Rob
gewizrepairs.co.uk
tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
Horn wont work and gear shifter locked
is your battery dead the shifter cant move until you push down the brake.
The alarm won't go off
Try this:
SAVE radio code and remove the negative battery cable,turn on the headlight switch for 30 seconds,turn back off,start truck.
That MAY re set the alarm relay.
Horn won't work
Sounds like the problem is in the horn pad if it works with the alarm.
4helpful
3answers
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Rover three wheel mobility scooter full charge horn working but just wont move
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Alarm sounds everytime key removed from ignition?
There is a switch either in or on the driver door that turns on the interior lights and tells the module the door is open and the key is still in the ignition, this sounds the alarm, check all the doors and make sure they turn the interior lights on and off when the doors are opened and closed.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
