Menu options do not display and nothing happens when you hi brew
Am I to assume it brews if you normal brew? It can be that normal brew is not controlled in the same way hi brew is, therefore when the control panel stops functioning and no screen display, the hi brew feature also stops working.
This casn only mean that either the circuit control is faulty and needs replacement. orthere is a bad connection that has finely shown or corroded to the point of not working completely. In either case, the unit needs to opened and tested & or visually insepected.
