1994 Ford Taurus Logo
ggarcia Posted on Apr 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why distributer drive gear lays done
Drive gear stripped replaced and it happened again in 3 days next ones been going 3 wks
Bill Boyd
Level 3:
Top Expert:
  • Ford Master 53,816 Answers
  • Posted on Apr 04, 2016
Bill Boyd
Ford Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11939847
Points
172802
Check the drive system for the distributor
ford employ a shaft that drives the oil pump and if the oil pump is under undue stress, it strips the gear or breaks a shear pin
all the gear is driving is a distributor shaft and in the first instance could be a seized bush for the shaft but with replacements failing I would be looking further afield , like an oil pump
Suzuki carry 660 autobox sticks in top gear
Make sure trans has proper amount of fluid...
Vehicle not shifting
Have you retrained the gear? From memory think goes motor running foot firmly on brake park to neutral three times, neutral to reserve three times, neutral to drive three times, keep going thru all gears Then drive car normal for ten minutes minium as you usually would.
2answers
I have a 2003 Utilimaster truck powered by a 5.7 Chevy 350. Last week it was turning over, but struggled to turn over. It started finally and I had no trouble cranking it for the rest of the day. The...
Sounds like you have a bad starter drive gear assembly (the gear on the starter that engages the flywheel gear). The drive gear has a one way clutch to prevent spinning the starter with the flywheel on engine start. When the clutch goes bad it does not spin the starter drive gear. If that's the case you can replace the starter drive rather than the whole starter, and you should also check the flywheel gear teeth to make sure none are broken or worn excessively.
Replaced starter 3 days ago ran fine. Went to go today car started up Put it in reverse and nothing tried drive nothing car will not move in any gear. fluid is good
the starter has nothing to do with it... taurus' are known for stripped out torque converters. most likely the case. about $1000 job
2answers
THE ENGINE CUT OFF CRANKED ONE TIME THEN SHUT
Sounds like your fuel pump is going bad. Have your mechanic do a pressure test on it.
1helpful
Car keeps stalling when brakes applied, then starts but turns off
I dont know why, but one time my truck was low on trans fluid and after I topped it off, it didnt stall anymore when put into gear. as fro the odometer i dont know, it may have to go out completely before any diagnosis can be done.
1998 Ford Taurus Station Wagon SE
CODE P500 VSS NO SIGNAL.PROBLEM COULD BE CONNECTOR TO VSS IS SHORTED OR THE MAGNET GEAR ON TRANSMISSION DRIVE SHAFT COULD BE BROKEN OR MISSING TEETH.
2001 hyundai accent gl auto trans prob
first clean the MAF mass air flow Vitally
Plug wire burn spots, spark plugs fouling, loss of power, misfire
optispark distributor fails. go to summitracing.com and search optispark. it'll pop right up
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
