Hi Shelagh, If you're trying to connect to your home Wi-Fi The password is on the back of the modem, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
SOURCE: i cannot use the Wi-Fi
check if your wi-fi detects any network
check the wi-fi stability you've got....
or try to reset/restore your phone to refresh...
SOURCE: galaxy samsung phone. He can't find wi-fi
He should read the manaul or call his cell phone provider's tech support.
If he still can't find wi-fi the wi-fi is turned off or hidden which can be corrected by the person who manages the wi-fi acces point.
I hope this helps him.
SOURCE: wi-fi pasword connot conect to wi-fi
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router. http://www.fixya.com/support/r10267861-network_security_key
