Necchi 537-L
Sandi, Machine made in Taiwan, My guess on age would be early 80's. Links below may help, first link one lady states buy her 537L from sears in 1982., other links are instruction and info.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Life With Lou Necchi 537L Sewing Machine
Necchi 536 FB 537 FA Sewing Machine Threading Diagram
http://www.sewingpartsonline.com/necchi-sewing-machine-instruction-manuals.aspx
Try google ---www.sewing-machines.blogspot.com.au as there is information as to the history of necchi machines
they were originally made in Italy to exacting standards and in 1950 an zigzag model was introduced
starting with the lydia model the machine started using plastic in the cam and other components so if yours has plastic inside, it is after 1950
there is another site-- www.geocities.com/lamx --that has a necchi collection so you may get information from there as well
I found sites after typing in --year of manufacture of necchi 537l sewing machine --so if you navigate around all the available sites you may get what you are after
SOURCE: Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
SOURCE: New belt for Necchi Lelia 513-
Hi. I hear such wonderful things about these Italian-made Necchi! Here are a couple of places you should be able to find your belt:
http://www.sewingpartsonline.com/sewing-machine-belts.aspx
Guy Baker at http://www.sewingmachineparts.net/ always seems to have (or be able to get) just about anything.
http://www.sew4less.com/category/43/Belts_Motor_and_Timing
and, finally: http://sewing-machine-parts-store.com/list.asp?subcat=Belts
Hope this helps!
Happy Sewing!
Robbie
SOURCE: Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
Testimonial: "Hi, thanks a lot. I don't know if it came with the oil, we assumed that it maybe needs oil (my father knew this from the old machines ;-) ) Again thank you very much for your quick answer!"
Sorry my picture didn't come up.
