Under the dash just left of the steering wheel.
Cavity
Fuse
Color
Description
F1
Spare
F2
Spare
F3
10 Amp
Red
Headlight high beam left
F4
15 Amp
Lt. Blue
Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094)
(Repair tip: WJ flasher repair)
F5
25 Amp
Natural
Radio amplifier
F6
15 Amp
Lt. Blue
Park lamps
F7
10 Amp
Red
Interior lights
F8
15 Amp
Lt. Blue
Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks
F9
20 Amp
Yellow
Power outlets
F10
20 Amp
Yellow
Adjustable pedals (2002-2004 only)
F11
10 Amp
Red
Rear window defrost indicator
F12
10 Amp
Red
Auto shutdown relay / "Fuel"
F13
Spare
F14
10 Amp
Red
Headlight low, left
F15
10 Amp
Red
Headlight low, right
F16
10 Amp
Red
Headlight high, right
F17
10 Amp
Red
Instrument cluster, diagnostic connector
F18
30 Amp
Trailer tow
F19
10 Amp
Red
Anti-lock brakes
F20
10 Amp
Red
Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense
F21
10 Amp
Red
Ignition Run / Start - PDC (Power Distribution Center)
F22
10 Amp
Red
F23
15 Amp
Lt. Blue
Brake switch
F24
15 Amp
Lt. Blue
Foglamps
F25
20 Amp
Yellow
Accessory delay relay (sunroof)
F26
15 Amp
Lt. Blue
Cigar
F27
15 Amp
Lt. Blue
Rear fog (export)
F28
10 Amp
Red
Body Control Module, Acc/Run
F29
10 Amp
Red
Rear wiper switch. Washer motors
F30
15 Amp
Lt. Blue
Radio
F31
10 Amp
Red
Ignition Start
F32
10 Amp
Red
Ignition Run / Start - Airbag
F33
10 Amp
Red
Ignition Run / Only - Airbag
C1
20 Amp
Yellow
Wiper (Circuit Breaker)
C2
20 Amp
Yellow
Seats (Circuit Breaker)
C3
Spare
I hope this helps :)
