This is model number UN46B7100WFXZA. I have white vertical lines running through most of the picture.
The common cause of this issue is down to a board that connects the screen to the main circuit video board of the tv. It is usually located top middle of the tv and has 2 white ribbon type wires coming from the top and is normally covered in a metal shield.
There will be a part number on the circuit board, this will be the one to find online which matches your screen. If you got an identical tv with another fault, it may not have the same part as each combination is different depending on the manufacturing line or part revisions.
The part you are looking for is called the T-Con board . Hope this helps.
