Motorcycles Logo
Zak Benney Posted on Apr 02, 2016
Scoot runs and drives fine but will not turn off by ignition
2008 Honda trx had low battery tried to start now the ignition doesn't work pops the 15 amp ignition fuse when I turn key on
Hey Scoot, I need a little more info,, if you have removed the battery cables, you may have hooked something up wrong..Did you replace the battery?? ; hopefully with an exact match of the old one.. double check you connections and reply to me.
I have a 2011 Vespa LX150 that has trouble starting every time. Most of the time, it continues to turn over but won't catch; sometimes it just makes a winding noise (like a wind up toy). I can usually get...
probably the starter relay has a malfunction.
- Or the gears on the starter were once damaged when you pushed the starter button by mistake while the engine was already running?
Usually the engine starts on the second try - if the battery is really good then you better try to live with that.
Buy a Voltmeter to check the battery charge.
Amazon com Ancel Bst200 100 1100 Cold Cranking Amps Portable 12V Car...
Sep 01, 2013 • Motorcycles
1helpful
2helpful
2answers
Car won't turn over randomly
When it will not crank, a mechanic would check for voltage at the starter, the clutch safety switch, and the key switch.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
