Pls help
SOURCE: nokia 6131 security code
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
SOURCE: i forgot my security code for nokia 6080 pls help.
Go to the site http://unlockme.co.uk and enter your phone’s IMIE number and press Enter then u’ll get the master code of your phone. 2. This master code can be used as lock code when we are asked for the security code.
3.But always we can’t remember master code and we want to use an easier lock-code then we can set a new security code of our own wish by giving the Master-code as our old security code when asked for old code while resetting security code.
e.g.NOKIA 6600
Tools -> Settings ->(scroll down) security -> Phone and SIM ->(scroll down) Lock Code
Then it asks for old code where u can type the master code and then set the new code as you wish.
When during formatting u are asked for lock code you can also enter Master code.
To get IMIE of your phone type *#06# on screen of your phones.
tell me if it doesnt work
SOURCE: orgot my security code Nokia 1100
Your IMEI: 359399009958078
Your Nokia Master Code: 6260611472
Steps to type Master Code:
1.This is master code.It has to be entered when your phone is started and asks for code..(security or master)..
2.If you type 5 times wrongly,the phone will get whole locked.. so,try 1 time.
3.If you fully typed 5 times wrongly ,you have to get a software tool to unlock and that costs greater than the phone you got..
so,try 1 time and let me know..
my email id:[email protected]
