Error msg mp 600
SOURCE: canon mp 150 error 5
Our pixma MP150 printer has a flashing E and flashing 5, also flashing on alarm, black ink and color ink. We have replaced the ink cartridges but nothing happens. They were empty. The printer doesnt recognize that the cartridges are there. We have tried unplugging the cords and taking the cartridges out and putting them in again. Also, it wont scan a thing either. ITs likes its frozen in the error. What can we do to fix this?
SOURCE: canon printer pixma mp110
My Pixma MP110 keep on displaying "CHECK PRINTER (5800)" Please have m to solve this problem
SOURCE: canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
SOURCE: error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
SOURCE: canon mp 600 error code 6A00
When the printer is not functioning properly you may need to reset it:
1) Press and hold <On/Off> for one second. Display will go blank. (If this does not happen, unplug the printer).
2) Wait approx. 10 seconds
3) Plug in the device - Press <On/Off> if necessary to power on the printer
4) Wait until the device has finished its startup routine
If the problem still persists, your MP600 may need servicing by a qualified technician.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Sometimes a fault in the processor or main board could cause this issue.
