I don't know if I need a new control or something or a new power switch
Follow the wires from the battery all the way to the motor. You should find a large amp sized fuse or a resettable circuit breaker in line. Razor PR200 24V Electric Motorbike Parts
SOURCE: i got a razor pocket rocket and my back wheel blew
Replacing the rear tire is a real nightmare.....you are much better off purchasing the entire rear wheel assembly which you can do from the Australian distributors Funtastic for only about $10-$15 more than if you just bought the tire.
To replace the tire you need to use a bench vice which a couple of bolts clamped into it to hold the hub in place.....you then need to remove the sprocket assembly which is a reverse thread......i had to use a hammer and a large flat head screw driver wrapped in a rag so as not to tear up the teeth.
Once you've loosened the sprocket assembly you have to undo the bolts the hold the two sides of the wheel together and the tire will come right off.
All of this would be totally unecessary if they used a tire that you could remove just like any other mini motorcycle tire.
They don;t and so it is what it is.
As I said, next time just buy the whole assemble and then it's very straight forward.
Hope that helps!
