A/C turns on and runs and blows cool air but not cold. Can hear breaker kick on but nothing. Please help!
SOURCE: No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
SOURCE: carrier fan unit
Poke the fan blade with a stick to see if the bearings are seized up. If it turns easily, you have an electrical problem, like a bad capacitor.
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
SOURCE: My Armstrong Concept 1000 5ton stopped running
Sounds like your low on refrigerant, presuming your compressor is coming on at all. Listen for a distinctively lower toned motor running other than the fan motor. Either problem necessitates an EPA certified Tech for a fix. Good luck
