Televison & Video Logo
Posted on Nov 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi tv we bought this tv and we had the remote controll while i was at work my daughter locked my dogs in the living room and they destroyed the remote to nothing so we were using the voume butten by the tv its self working good then sat i changed the living room around and all i did was unplug the instention cord that plugs all cords in it and the modem that goes to the cable box and now all im seing on the screen is this input is locked use the 10-keypad to enter your personal code,then press enter to veiw.was wondering if you have any idear how i can fix this ,thanks elizabeth kennedy
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2844
Points
5
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Nov 18, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
584959
Points
2786
Www.mrremotecontrol.com might help with a new remote.
Then,push 9 and QV at the same time..........................T.
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
2helpful
2answers
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Remote control switch destroyed
If you get an universal remote, you won't have all functions to control the TV. Moreover, the codes for many audiovox model are often not reported on universal remote manuals , therefore you may need to use autodetect feature on universal remote.
The best choice is buying a replacement original remote like the ones below:
New Original TruTech PLV31199S1 Remote Control
$39.95 -
New Original Trutech PLV31199S1 Remote Control $39.95
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
2answers
UMC J20/1U12G Set - Need Remote Control Code
i bought a ross remote control as i lost mines while i was moving houses & it works fine but when he batteriies ran out it resets its self & now i dont have the code to out in bk it for the remote towork again
My tv is locked it is a mitsubishi 305-301 i my daughter is 7 and she locked it. please help
this may work for you if not e-mailme @ [email protected] uoy need original remote control (select no lock channel press press mode untill lock display press 9 and QD same time boht good luck....
Dog destroyed my romote
isn't it on the right side (when looking at tv)? my polaroid buttons are. good luck.
Hunter Remote Control # 27185
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Remote Control
Re-search this forum, I posted a fix using a DirectTV remote in another thread. Happy hunting! :)
3answers
Remote Control
Sorry to say but it is very hard to get parts for this brand. I don't take them for repair anymore. I have a few Duraband remotes. If you can give me the model number of yours, maybe I have a matching one for you.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
