I can tap it with a hammer and it will start and others it want. Also I checked and when it want start with the key in the start position I only have 7.5 volts put 4 starters
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Battery is low. Either the battery is bad or the charging system is bad. You should read 12.5 volts or more when not running, 14 volts when running.
